I’ve been a ValueHost customer of Jodo for more than a year now.
Everything is working fine till now and was satisfied with the service of Jodo.
But off late my clients have started askign for new technologies and new features. One client is asking for JSP support, another private nameservers.
So was planning to go for a VPS, but i don’t know anything about Server Administration.
I’ve been a webhosting service provider since 2003 though, used cPANEL and H-Sphere.
And while i was going through the forums, i came to know about the following points, May i request anyone to clarify..?
Windows VPS are not fully managed. If not fully managed, then what is in the Jodo’s purview..? and what all is in my purview.
Are all the support tickets from VPS clients charged..? Else what is charged extra..?
Can i create reseller accounts so that they can create unlimited end user accounts under them.
Can i provide them private nameservers and other normal features of plesk windows webhosting. If yes, do i need Dedicated Ip’s for all the nameserver entried i create for my client.
If i go for a Windows VPS Silver plan, can i install MS SQL Express (guess it is free - BTW what is the difference between Normal MSSQL that JODO has on its server and MS SQL Express).
5 -a) If i can install MSSQL Express, how will users be able to maintain databases. Do we get ASP.NET MSSQL Manager as in H-Sphere Reseller account..?
Can i oversell Webspace / Bandwidth in Windows VPS..?
Guess thatz all for now.
Early response in this regard is much appreciated.
We aid you with finding the correct docs, if there is a plesk bug we aid in getting you support, and we do windows updates about once a month.
No support tickets are charged unless they require us to login for a non bug matter. $3 per ticket is charged only for management of your VPS.
Plesk is a bit different than hsphere so far as resellers, but you can create a reseller that allows multiple domains with seperate logins under them, it is not an issue.
you can do private nameservers, in fact by default I believe Plesk makes private nameserver entries in DNS, which one can use, or they can use the host DNS as well(either name will work) it can use shared IPs for private DNS, no require for each to be unique.
Above you mentioned that “We aid you with finding the correct docs, if there is a plesk bug we aid in getting you support, and we do windows updates about once a month.”
So say for instance the VPS goes down for some matter, then it will not be up until i see it is it..?
“> Plesk is a bit different than hsphere so far as resellers, but you can create a reseller that allows multiple domains with seperate logins under them, it is not an issue.”
Can you quote few examples how it is different than H-Sphere as i’ve not used Plesk. I’ve used only cPANEL and H-Sphere.
You can use alerting services for this, we do not monitor, if this is a needed service we could work out something. You have access to a power panel even if your VPS is off to restart/control it as well.
Thank you very much for those replies.
As suggested by Nzkiwi, i went through the Plesk Demo and it seems to be good.
Ofcourse it is not as handy as H-Sphere though.
There were 4 Logins,
Admin (which i understood)
Client (Is this a reseller kind of access or how is it..? Din’t understand much)
Domain (Is this a end user account / per domain control panel or something?)
Mail (Which i think is only for mail access)
And secondly, will users be able to access FTP from FTP client..? I din find how to create a FTP User. All i found was Web User which i did not understand.
Btw What is a Web User..?
One more thing, i’m planning to go for Windows VPS Silver plan and will let you know shortly (coz one of my clients wanted a reseller hosting, if he comes to me, then will have to take a vps to provide him that plan).
I’ll have Plesk Unlimited with Powerpack, Tomcat and MS SQL 2005 Express installed.
I’m very much happy with the H-Sphere Windows reseller speed / uptime.
And if i buy VPS also, i would like to maintain that sort of response time / uptime.
Now my question is with that much of RAM, approximately how many Domains / end user control panels can i host on the VPS (say most of my client’s websites will get a max of 100 visitors per day and they are all not very heavy resource consuming websites. They are websites with around 50 pages and a single MS SQL database which is queried for Login info and other trivial information that is stored in it.)
I know it is very hard to guess, but a conservative figure will do.
