Plesk Java Applications
I have a Windows hosting package wuth Plesk at my current host that doesnt let me install Java Applications (.war) files into the root of the domain. Instead it installs it into a subfolder with the name of the war file e.g http://spratnets.com/hh/
i need a WINDOWS host that lets you install a war file into the root. Does Jodohost do this ?
You get Plesk here (if you opt for it) with our Windows VPS plans:
http://jodohost.com/windows-vps.asp
Since it is a VPS, you get admin access to everything installed.
With a bit of extra effort on locating and modifying the right configuration, you can get your application deployed the way you want it.
