Plesk Versions
Is Plesk Reloaded consirdered the powerPack??
For Virtuozzo is it version 3.5 currently being used??
Virtuozzo 3.5.1.something(it changes every update)
Using Plesk 7.6.1 on current installs and I am in the process of testing a new unreleased version :slight_smile:
No Reloaded doesn’t mean power pack.
It basically falls like this on Value you get:
Plesk
30 domain license
Ability to use asp.net 1.1/2.0, asp, php, perl
Have client control panels for web, email, etc
This is by no means an exhaustive list, but then when you get Silver or higher VPS it adds:
Helpdesk
MSSQL support, installed
CF support, cf not installed
Unlimited domain license
Ok reason for the powepack question, is I need a box it comes in for a picture, for my website. I can’t fine one.
What is the real name of the powerpack software upgrade is it Plesk Plus?
Do we use Pleak Reloaded for anything?
:slight_smile: I don’t know of any box, we get everything via FTP from swsoft :slight_smile:
http://www.swsoft.com/en/products/plesk76win/addons/
it all has the same pic.
