PMachine's ExpressionEngine
Has anyone here used PMachine’s ExpressionEngine or their PMachine Pro blogging software?
If so what are your opinions?
[QUOTE=gsaunders]
Here are the requirements… (Does everything look ok here? What about the imaging stuff?)
ExpressionEngine Requirements
In order to run ExpressionEngine your web server must support:
* At least 10 MB of space
* PHP version 4.1 or newer.
* MySQL version 3.23.32 or newer.
* PHP must have XML support.
* Your server must have the following MySQL grant privileges (for tables): CREATE, ALTER, DROP
Notes
To take advantage of the image thumbnailing feature your server must support one of the three image manipulation protocols: GD, ImageMagick, NetPBM.
It should work fine. GD2 is now bundled with PHP and Imagemagick is available in almost all servers.
