I have a client who I’m migrating their production site to 2.0. In the meantime they need to perform acceptance on the 2.0 version.
Would it be possible to have a 1.1 site running at domain.com while having 2.0 running at sub.domain.com ?
If so, should I create the subdomain and then contact support to make it 2.0?
How would you suggest I proceed?
Brent
Stephen
January 20, 2006, 12:06am
2
Yes, we can do a subdomain in 2.0 as long as it is on a 2.0 supported server(win2 or win13)
I’ll check which server it’s on. If it’s not on one of those you mentioned, i’ll first have to move the main domain and then add the sub-domain, correct?
But the main domain will still run 1.1, correct?
Thanks again,
Brent
You can’t move only domains, only full accounts, but yes if not a 2.0 supporting domain you would need to move the account.
