With the available plans, can i use Flash remoting via the built gateway in cold fusion? ( flash → cfc.componet – CF-cfc.componet - flash)
Thanks for you help
Thanks for you help
Hi
We do not have macromedia Flash Remoting installed which is a separate product I believe.
However if CF has some inbuilt component, you may use it..
Great thanks for your help
