Problem AspSmartUpload
Hello there,
I am having problems with rewritting the following code into the Javascript.
The vb code Works fine, but unfortunatelly I need to have it witten in JS.
Sample3.htm
aspSmartUpload : Sample 3
Sample3.asp
On Error Resume Next
’ Variables
Dim mySmartUpload
Dim intCount
’ Object creation
Set mySmartUpload = Server.CreateObject(“aspSmartUpload.SmartUpload”)
’ Only allow txt or htm files
mySmartUpload.AllowedFilesList = “htm,txt”
’ DeniedFilesList can also be used :
’ Allow all files except exe, bat and asp
’ mySmartUpload.DeniedFilesList = “exe,bat,asp”
’ Deny physical path
mySmartUpload.DenyPhysicalPath = True
’ Only allow files smaller than 50000 bytes
mySmartUpload.MaxFileSize = 50000
’ Deny upload if the total fila size is greater than 200000 bytes
mySmartUpload.TotalMaxFileSize = 200000
’ Upload
mySmartUpload.Upload
’ Save the files with their original names in a virtual path of the web server
intCount = mySmartUpload.Save(“/aspSmartUpload/Upload”)
’ sample with a physical path
’ intCount = mySmartUpload.Save("c:\temp")
’ Trap errors
If Err Then
Response.Write(“Wrong selection : ” & Err.description)
Else
’ Display the number of files uploaded
Response.Write(intCount & " file(s) uploaded.")
End If
Help will be very appriciated.
We are having component aspsmartupload from www.aspsmart.com and all the samples work
correctly but we need to have it rewritten into javascript.
Javascript is client side, and aspsmartupload is tool that works with a dll on windows servers, I don’t think you can make that 100% javascript.
I am not using only javascript, I intend to use asp with javascript. all those samples are using asp with vbscript and want to rewrite it using asp with javascript. I hope it is possible since I havent find any similar example on net.
ok, I understand now, I don’t know how to do that, but prehaps another person does.
[SIZE=1]
Give this a try!
<%@ Language=JScript %>
window.onerror=null;
// Variables
var mySmartUpload;
var intCount;
// Object creation
// I think you can use Server.CreateObject too but im not positive
mySmartUpload = new ActiveXObject(“aspSmartUpload.SmartUpload”);
// Only allow txt || htm files
mySmartUpload.AllowedFilesList = “htm,txt”;
// DeniedFilesList can also be used :
// Allow all files except exe, bat && asp
// mySmartUpload.DeniedFilesList = “exe,bat,asp”;
// Deny physical path
mySmartUpload.DenyPhysicalPath = True;
// Only allow files smaller than 50000 bytes
mySmartUpload.MaxFileSize = 50000;
// Deny upload if(the total fila size is greater than 200000 bytes
mySmartUpload.TotalMaxFileSize = 200000;
// Upload
mySmartUpload.Upload;
// Save the files with their original names in a virtual path of the web server
intCount = mySmartUpload.Save(“/aspSmartUpload/Upload”);
// sample with a physical path
// intCount = mySmartUpload.Save("c:\temp")
// Trap errors
if(Err){
Response.Write(“Wrong selection : ” + Err.description);
}else{
// Display the number of files uploaded
Response.Write(intCount + " file(s) uploaded.");
%>[/SIZE]
Hi Doctorallia,
Your example don’t work me .
error masage in line :
what is the error?
I am not too good with debugging jscript.. since i hardly ever use it.. but i can try.
error is this line .
write in form : oSmartUpload.Upload ();
error :
Request object error ‘ASP 0206 : 80004005’
Cannot call BinaryRead
write in form : oSmartUpload.Upload ;
error :
HTTP Internal error Internet Explorer
This is shortly examples , also are there identical problem.
Error Line: oSmartUpload.Upload () ;
Error masage :
----------------------------Samples ASP whith VBscript—
<% Dim oSmartUpload Dim file Dim intCount intCount=0
Set oSmartUpload = Server.CreateObject(“aspSmartUpload.SmartUpload”)
oSmartUpload.Upload
For each file In oSmartUpload.Files
If not file.IsMissing Then
file.SaveAs("c:\Temp" & file.FileName)
Response.Write("Name = " & file.Name & “
Response.Write(“Size = " & file.Size & “
intCount = intCount + 1
End If
Next
Response.Write(intCount & " pocet suborov odoslanych na server.
-----------------------Samples Asp whith JavaScript—
<% var oSmartUpload, file, intCount, i ; var intCount=0 ;
oSmartUpload = Server.CreateObject(“aspSmartUpload.SmartUpload”);
//oSmartUpload.Upload ;
for(i=1; i<= oSmartUpload.Upload.Files; i++);
file.SaveAs("c:\Temp"+file.Name);
Response.Write(“Name = " + file.Name + “
Response.Write(“Size = " + file.Size + “
intCount=intCount + 1 ;
Response.Write(intCount+” pocet suborov odoslanych na server.
I have the some probs
Please help me how to use AspSmartUpload in ASP with Javascript
hello,
is theres another upload script instead of aspsmartupload, because i only know aspsmartupload
please advise
thanks
There is ASPUpload, you can also do uploads in pure asp without need fo a com object, and finally we have DundasUpload installed.
the ASPSmartUpload has been unsupported by the developer for a long time now, and some windows patches a year or so back seemed to break many functions on aspsmartupload.
Following error occurred when i creating SmartUpload object.
Error :Server object: 006~ASP 0177~Server.CreateObject Failed~800401f3
this error occred only in windows server 2008.
in windows server 2003 it’s working fine
here is my used code
Dim strFileName
mimeType = “application/msword”
strPath = “C:\Warna\ClasscASp\Document”
docNumber = “000001”
extension = “doc”
Set MyUpload = Server.CreateObject(“AspSmartUpLoad.SmartUpLoad”)
MyUpload.ContentDisposition = “inline”
MyUpload.DownloadFile strPath & docNumber & “.” & extension, mimeType, strFileName
Response.Flush()
Can anyone have idea wt should I do with windows server 2008?
change upload objects, aspsmart company stopped supporting aspsmartupload about 2.5 years ago :frowning:
I’d recommend aspupload
it even breaks on windows 2003 servers with some patches, and sometimes works, very bad one to use.
Thanks Stephen.Do you know any open source product smiler to aspsmartupload???
i don’t know any open source, there is that is free however.
