Here’s the actual sql script for the tables:
USE [realtou_agent]
GO
/****** Object: Table [dbo].[t_agent] Script Date: 09/28/2006 11:26:09 ******/
SET ANSI_NULLS ON
GO
SET QUOTED_IDENTIFIER ON
GO
SET ANSI_PADDING ON
GO
CREATE TABLE [dbo].[t_agent](
[agent_id] [int] IDENTITY(1,1) NOT NULL,
[agent_guid] [uniqueidentifier] NOT NULL CONSTRAINT [DF_t_agent_agent_guid] DEFAULT (newid()),
[agent_sNameFirst] varchar COLLATE SQL_Latin1_General_CP1_CI_AS NULL,
[agent_sNameMiddle] varchar COLLATE SQL_Latin1_General_CP1_CI_AS NULL,
[agent_sNameLast] varchar COLLATE SQL_Latin1_General_CP1_CI_AS NULL,
[agent_sNameFull_assistant] varchar COLLATE SQL_Latin1_General_CP1_CI_AS NULL,
[agent_sEmail_assistant] varchar COLLATE SQL_Latin1_General_CP1_CI_AS NULL,
[agent_sPhone_assistant] varchar COLLATE SQL_Latin1_General_CP1_CI_AS NULL,
[agent_sTitle] varchar COLLATE SQL_Latin1_General_CP1_CI_AS NULL,
[agent_sAddress] varchar COLLATE SQL_Latin1_General_CP1_CI_AS NULL,
[agent_sCity] varchar COLLATE SQL_Latin1_General_CP1_CI_AS NULL,
[agent_sZip] varchar COLLATE SQL_Latin1_General_CP1_CI_AS NULL,
[agent_sPhone] varchar COLLATE SQL_Latin1_General_CP1_CI_AS NULL,
[agent_sFax] varchar COLLATE SQL_Latin1_General_CP1_CI_AS NULL,
[agent_sWebsite] varchar COLLATE SQL_Latin1_General_CP1_CI_AS NULL,
[agent_sLogoURL] varchar COLLATE SQL_Latin1_General_CP1_CI_AS NULL,
[agent_sPhotoURL] varchar COLLATE SQL_Latin1_General_CP1_CI_AS NULL,
[agent_boolActive] [bit] NOT NULL CONSTRAINT [DF_t_agent_agent_boolActive] DEFAULT ((1)),
[agent_boolRegistered] [bit] NOT NULL CONSTRAINT [DF_t_agent_agent_boolRegistered] DEFAULT ((0)),
[agentLogin_id] [int] NULL,
[state_id] [int] NULL,
CONSTRAINT [PK_t_agent] PRIMARY KEY CLUSTERED
[agent_id] ASC
)WITH (IGNORE_DUP_KEY = OFF) ON [PRIMARY]
) ON [PRIMARY]
GO
SET ANSI_PADDING OFF
GO
/****** Object: Table [dbo].[t_agentLogin] Script Date: 09/28/2006 11:26:09 ******/
SET ANSI_NULLS ON
GO
GO
SET ANSI_PADDING ON
GO
CREATE TABLE [dbo].[t_agentLogin](
[agentLogin_id] [int] IDENTITY(1,1) NOT NULL,
[agentLogin_sEmail] varchar COLLATE SQL_Latin1_General_CP1_CI_AS NOT NULL,
[agentLogin_sUsername] varchar COLLATE SQL_Latin1_General_CP1_CI_AS NOT NULL,
[agentLogin_sPassword] varchar COLLATE SQL_Latin1_General_CP1_CI_AS NOT NULL,
CONSTRAINT [PK_t_agentLogin] PRIMARY KEY CLUSTERED
[agentLogin_id] ASC
) ON [PRIMARY]
GO
GO
/****** Object: Table [dbo].[t_state] Script Date: 09/28/2006 11:26:09 ******/
SET ANSI_NULLS ON
GO
GO
SET ANSI_PADDING ON
GO
CREATE TABLE [dbo].[t_state](
[state_id] [int] IDENTITY(1,1) NOT NULL,
[state_sName] varchar COLLATE SQL_Latin1_General_CP1_CI_AS NOT NULL,
[state_sDesc] varchar COLLATE SQL_Latin1_General_CP1_CI_AS NULL,
CONSTRAINT [PK_t_state] PRIMARY KEY CLUSTERED
[state_id] ASC
) ON [PRIMARY]
GO
Here’s the errors:
Msg 170, Level 15, State 1, Line 26
Line 26: Incorrect syntax near ‘(’.
Msg 170, Level 15, State 1, Line 9
Line 9: Incorrect syntax near ‘(’.
Msg 170, Level 15, State 1, Line 8
Line 8: Incorrect syntax near ‘(’.
