Problem setting up DSN Servers
Hi, I just signed up for a reseller account and I was following the step-by-step guide but when I went to godaddy.com to create the name servers with the ip address provided from the control panel godaddy.com keep sending me an emal with an error message..
Here is the message:
The registration of NS1.WASTEDHALO.COM has FAILED.
The IP you requested for this name server was:
24.10.105.94
Error: (551) Parent domain status does not allow for operation;
Please contact GoDaddy.com for assistance.
http://www.godaddy.com/gdshop/support.asp
It seems like the control panel is giving me the wrong IP addresses or something.
Also my domain “wastedhalo.com” is being used and is still pointing at my old hosts dnd servers, I don’t know if might cause this.
  1. First you need to create name servers from IPs in your Reseller Control Panel. Then visit Godaddy FAQ page on how to do it - https://www.godaddy.com/gdshop/faq/faq.asp?se=%2B&faq_id=113&topic_id=17&topic=Domains
  2. Now change name servers of your domain at Godaddy. Visit Godaddy FAQ page on how to do it - https://www.godaddy.com/gdshop/faq/faq.asp?se=%2B&faq_id=94&topic_id=17&topic=Domains at Godaddy.
It doesn’t tell you to go to godaddy untill after you create the name servers in the control panel, so of course I set them up, how else would I have had the IP addresses to use at godaddy???
Ok, Just in case anyone else has this problem…
You have to set the name servers for your domain to
ns.mhere.biz & ns2.mhere.biz
Then create the DNS servers with the registar.
Once my dns servers are working I’ll set them to be used by my domain.
