Problem with ASP.NET
I have the folowing error when I run The application on the host, but when I run the application on the local machine is everything OK.
Please somebody help me.
Server Error in ‘/’ Application.
Runtime Error
Description: An application error occurred on the server. The current custom error settings for this application prevent the details of the application error from being viewed remotely (for security reasons). It could, however, be viewed by browsers running on the local server machine.
Details: To enable the details of this specific error message to be viewable on remote machines, please create a tag within a “web.config” configuration file located in the root directory of the current web application. This tag should then have its “mode” attribute set to “Off”.
Notes: The current error page you are seeing can be replaced by a custom error page by modifying the “defaultRedirect” attribute of the application’s configuration tag to point to a custom error page URL.
It means you have an error but your web.config file has a setting which prevents the server from revealing the details of the error to any Joe User who might be using your website. Edit the web.config file located in the root of the directory and change the configuration option to OFF.
-Dave
ps. The error you’re seeing is typical of forgetting to compile the application and placing the new DLL file in the bin\ directory. Try that.
