Problem with JodoPulse.com
There was an issue with the renewal of jodopulse.com registration, and it did not renew prpoerly. So the domain is showing to be expired. We are working to get this up ASAP with DirectI. Rest assured we are still monitoring and it is still going, just having to use another method to see the results.
For temporary I have made the jodopulse.com work at: http://204.10.110.227:9090
Some of the links are not working at the moment as they use the domain for status, but you can change to the IP given here at the ports on the links, and they will function.
As I am typing this the renewal has finally processed, but it may be a couple hours before it is working 100% again.
It is fine now.
