Server Error in ‘/’ Application.
Configuration Error
Description: An error occurred during the processing of a configuration file required to service this request. Please review the specific error details below and modify your configuration file appropriately.
Parser Error Message: It is an error to use a section registered as allowDefinition=‘MachineToApplication’ beyond application level. This error can be caused by a virtual directory not being configured as an application in IIS.
Source Error:
Line 44: </system.codedom>
Line 45: <system.web>
Line 46: <machineKey
Line 47: validationKey=“F9D1A2D3E1D3E2F7B3D9F90FF3965ABDAC304902”
Line 48: decryptionKey=“F9D1A2D3E1D3E2F7B3D9F90FF3965ABDAC304902F8D923AC”
Source File: D:\xxxxx\xxxxxx\ozdemir.info\portal\web.config Line: 46
Show Additional Configuration Errors:
It is an error to use a section registered as allowDefinition=‘MachineToApplication’ beyond application level. This error can be caused by a virtual directory not being configured as an application in IIS. (D:\xxxxx\xxxxxx\ozdemir.info\portal\web.config config line 93)
It is an error to use a section registered as allowDefinition=‘MachineToApplication’ beyond application level. This error can be caused by a virtual directory not being configured as an application in IIS. (D:\xxxxx\xxxxxx\ozdemir.info\portal\web.config line 154)
It is an error to use a section registered as allowDefinition=‘MachineToApplication’ beyond application level. This error can be caused by a virtual directory not being configured as an application in IIS. (D:\xxxxx\xxxxxx\ozdemir.info\portal\web.config line 162)
i’m getting this error when i try to install DNN 4.08.01 to my web. could you please help me about this? what is virtual directory and why should it identified as a virtual folder? i install DNN 3.X.X before in my web but in win21. win2 is not convenient to install these application?
