Problems login in to our control panel
It won’t accept my user id and password. Has the url changed for this resource since the migration?
Thanks in advance for your help.
No it has not changed.
However it will SOON change to a user selected or auto generated on first ticket, we will mass mail when that happens.
I’d recommend emailing a ticket using the addresses here:
Help & Knowledge Base - OPSPI Quick Start Guides | JodoHost
you can also email the vps desk if needed, just make it clear it is now a vps request.
Can’t login either. The login form just sitz and spinz.
