Promotions on a plan
Hi, I’ve read the documentation about using promotions on plans, but I hvae a doubt as to if I use a promotion and customers sign up using that promo code, can I later disable that promotion and they keep getting that discount? Or do I have to keep it enabled as long as I have a customer that signed up with that in order for them to keep getting the discount?
Thanks.
Promo codes under promotion applies to new signups only. Also you can setup multiple promotion schemes for your plans.
So create “Unnamed Promotions” for continous promotions.
Docs: http://www.psoft.net/HSdocumentation/reseller/promos.html#types
