Question about backups
Hi!
Do you take daily backups on all files and also all databases on reseller accounts?
Yes, backups take place every 24 to 48 hours. Everything from users files to systems files to databases are backed up.
We have a very extensive backup policy that is audited regularly
Great, Thanks!
Yash, just a question concerning MS SQL database backups.
If during the night, a hacker breaks into my DB and deletes some tables, how easy is it for you to replace the data from a copy that is from a day before?
Thankfully, nothing has ever happened, but I have to plan for the day… :frowning:
Nathan
We have already put in strategy, to avoid such situations.
However, If you feel such, just send us a ticket with “Urgent” in subject line. And we will restore your one day earlier backup.You can also use Live-Chat for more prompt support.
Hello,
We can easily restore SQL backups within 1-2 hours unless there is a larger problem, many times it is even faster than that.
