Question about ns ..
Hi, i have a customer in other place in cpanel, and use ns1 and ns2 of my main domain. He want some things present in hsphere, for other domain, but want be in the same domain name in ns because he think is other business.
Is possible sign for a new lite reseller plan.. but use the ns1 and ns2 in other place ?
It is POSSIBLE but highly NOT RECOMMENDED, You will have to manually create literally hundreds of DNS records for it to work properly.
Damn … Thanks for the info , i seek other aproach then.
just as a FYI, every time you submit a “server alias” it is making A records, every time you create a domain in hsphere it creates at least 8 DNS records, you would need to manually handle this each new server, each new domain on a manual basis.
I know one reseller that does it using DNS Made Easy, but he spends a long time each month.
Is too much hassle… I need think in other plan … :stuck_out_tongue:
Plan B can be use the .com.mx version of my site =P
Do u have already any reseller using a com.mx domain ? The TLD resolve very soon and i think the initial setup can be very quickly …
Yes there are some using .com.mx :slight_smile:
Ok, then probably i sign for other reseller lite soon, i need talk with the customer but he is out of office until Monday.
Thanks again
Other strange petition. The customer i am saying, have in other place a Helm account, because he need a ftp to only “write” and cant read, and other ftp only read but not write.
Its possible do some similar ? i think two fixed ip for ftps are needed…
what about creating a API ASP /PHP page where you set add domain and it adds the domain and adds the specified domain aliases
