Remote Desktop
[font=Tahoma]Hello ,[/font]
[font=Tahoma]I am trying to connect to JodoHost Server through Remote Desktop Connection.[/font]
[font=Tahoma]Then I connected with RDT,JodoHost server denies my access.What shoul I do?[/font]
[font=Tahoma]Ho can I send you the pictures of that?[/font]
[font=Tahoma]Thank you in beforehand,[/font]
[font=Tahoma]ProJester.[/font]
You cannot connect to any windows server via Terminal Services or Remote Desktop
To upload files, you can use the control panel or FTP
[font=Verdana]Dear Yash,[/font]
[font=Verdana]Thank you very much for the fast reply![/font]
[font=Verdana]But wouldn’t it be easier to connect to JodoHost windows server via Remote Desktop.[/font]
[font=Verdana][/font][font=Verdana]It is visual and clear. Maybe for an additional fee?[/font]
[font=Verdana] [/font]
[font=Verdana]Thank you again,[/font]
[font=Verdana]ProJester.[/font]
It’s a security risk. We like to keep access restricted to our servers as much as we can.
[font=Verdana][font=Tahoma]Dear Yash, Another question:[/font][/font]
[font=Verdana][font=Tahoma] [/font][/font]
[font=Verdana][font=Tahoma]From the Visual Studio.NET you can upload files directly into Hosting Account.[/font][/font]
[font=Verdana][font=Tahoma]Why JodoHost not in the list?[/font][/font]
[font=Verdana][font=Tahoma]Some companies, like [/font][font=Tahoma]http://www.vianetworks.net[/font][font=Tahoma] that charges [/font][/font][font=Arial][font=Tahoma][size=2]$1.99 / month[/size][/font][font=Tahoma][size=2] is in the list and JodoHost is not. It will be very convenient to upload files directly from the project into JodoHost Server.[/size][/font][/font]
[font=Arial][font=Tahoma][size=2] [/size][/font][/font]
[font=Arial][font=Tahoma][size=2]Thank you again, ProJester.[/size][/font][/font]
You can upload direct from visual studio I believe, you can also make web folders from your machine to your FTP account.
No, Stephan.
Just the selected Host Providers.
But, you are right about web folders from local machine to server FTP account
In any case thank you. :slight_smile:
