Hello,
I have a customer that needs to renew their SSL certificate.
When he went to renew it asked for a CSR, I do not see how you can generate a CSR from the control panel when a SSL certificate is already installed.
Any ideas?
Hello,
Any ideas?
Hello,
If you have old CSR, then you can renew your ssl certificate use old CSR. If you have not then you can generate new CSR through control panel after disable installed ssl.
