Ruby on Rails on Linux VPS?
Is it possible to install and run RoR websites on your Linux VPS?
Ton.
You have full admin rigths in VPS. So, yes. (I install django, a similar stack on python)
What about RoR as a standard service? Does JodoHost has any plans of supporting this soon?
Thank you.
On Linux side, I plan to look into it after we move our current cluster to Hsphere 3.0.
It can be setup on a VPS account anytime, as mamcx mentioned.
If low on load, it can be shared between a couple of clients of yours too.
Do you mean shared inside a VPS? What would be necessary to do that?
Thank you!
Yes, i meant inside a Linux VPS. Try this:
RailsOnRHEL in Ruby on Rails
Note: yum may need 200MB+ of RAM to resolve dependencies
