Script timed out
Hi, im getting this error when i upload large files:
Active Server Pages error ‘ASP 0113’
Script timed out
/bo/progress_upload.asp
The maximum amount of time for a script to execute was exceeded. You can change this limit by specifying a new value for the property Server.ScriptTimeout or by changing the value in the IIS administration tools
How can i fix it?
Thanks in advance, Ignacio.
We will need to know which server you are on and your domain.
What size large files are we talking about? 8MB or so should be doable on HTTP, more than that can get ugly.
I think u just have to add the max time u want by using: Server.ScriptTimeout = 1800
Costas
Great!
That works perfectly. Thanks a lot.
Ignacio.
