Hi I am moving over from brinkster where I need a fairly long map path
ie:
cnn.Open “Provider=Microsoft.Jet.OLEDB.4.0;” & _
“Data Source=\premfs8\sites\premium1\ursname\database dir\blah.mdb;” & _
“Persist Security Info=False”
From reading stff in hear I understan the database goes into the root (login) Directory
So should my map path be a simple
“Data Source=blah.mdb;” & _
Or am I missing something ?
Thanx Topshed
Yash
2
No, this would be correct:
Data Source = Server.MapPath(“../blah.mdb”)
Make sure you request Parent Paths to be enabled on your domain (by opening a ticket) otherwise that would generate an error
thanks Yash,
I will give it a try
Topshed
[QUOTE=topshed]
thanks Yash,
Well I took a ticket and they fixed it but I still get an error or just a blank screen. I am using :
cnnSearch.Open “Provider=Microsoft.Jet.OLEDB.4.0; Data Source = Server.MapPath(“yadyada.mdb”)”
Any ideas welcome
Topshed
Yash
5
umm… no, that statement is incorrect
[CODE]<%
Dim sPath
sPath = Server.MapPath(“../mydb.mdb”)
cnnSearch.Open “Provider=Microsoft.Jet.OLEDB.4.0; Data Source=” & sPath
%>[/CODE]
I’m really not an ASP expert but that should work.
