shared certificate
Does anyone know if there is a shared SSL certificate you can use for your client sites without actually buying one???
I’m about to move from Unitedhosting where I already use theirs for my oscommerce sites but hesitating in case jodo dont have one and it involves the extra expense of buying one.
Also, does anyone know if its easy to install your own cert if that is the case, as it is with unitedhosthosting
Pete
Yes, Please read shared ssl docs at : http://www.psoft.net/HSdocumentation/reseller/installing_shared_ssl_certificates.html
We will install your SSL certificate. You need to sent us ssl cert files and key by a ticket.
Cheers Ravi, that’s a big relief and a big help!
Just another quick question if I can…what BBS forum would you recommend to use???
Thanks again
Pete
:slight_smile:
BBS/Forums I recommend
windows- WebWizGuide Forums
PHP/unix - vBulletin for the best paid
PHP/unix - SMF for the best free.
Thanks Stephen
Are there any that you can automatically install on a site on a reseller account. I have one but have not yet taken the plunge and put a site up
phpbb has an autoinstaller, but I would not recommend my worst enemy install it :smiley:
So of the 3 you recommend above which one would you use on a reseller account???
:slight_smile:
I found this one, It’s PERL but I like it and going to use it, seems stable and works great, and they are on top of things with it.
http://www.yabbforum.com
The best paid I agree with Stephen Vbulletin, the best out there.
is vbulletin easy to install???
:slight_smile:
anyone?
Why not get a $14.95 certificate to secure your website, not much for a year… It’s better since you see your full domain with https:// and get the little padlock on the status bar (not achieved with shared SSL).
Not sure never used it, but I would guess it’s not any harder if not easier then any of the others.
I have heard nothing but good things about v-bulletin.
Whoa!..hold on there…$14.95 for a secure certificate!!!
where from???
Re the vbulletin thing (sorry there are 2 threads going on here) but I read on here somewhere that something didn’t work with the software and jodo???
has anyone else read that here??
thanks all!
:slight_smile:
What do you mean it doesnt work? This is vBulletin, running on our servers :smiley:
Yep, I see what you mean Stephen…DOH!..no but I’m sure I read that it required some sort of jiggery pokery to get it working on your servers and that it wasn’t easy…
dave96…where do you get a $14.95 cert from???
:slight_smile:
litessl.com - 14.95
godaddy.com - 19.95
rapidssl.com - 69.00
Note there are diferences between SSL besides the prices :wink:
Is this litessl OK for accepting credit card details does anyone know??
I buy certificates for JodoHost from http://certs.ipsca.com .
They accept PayPal and they aren’t too expensive. They process the certificate pretty quickly too
