simple instructions by client software?
Are there pre-made instruction sheets anywhere that give all the details and options for setting up various mail clients for resellers to give to their customers (maybe with minor customization).
I often feel like I am guessing or having to refer to previous setups and walk a new customer through setting up outlook, for example. Does something exist that is correct, and maybe includes a few versions of outlook and other clients, for POP and/or IMAP (for cluster 1)? It’s not that it is usually difficult, but I would rather have a step-by-step from the horse’s mouth, and have a better chance of the customer getting it right on their own, the first time.
Appreciate any link or guidance. thanks.
Anything specific?
It is pretty straightforward mail.domain.com (unless your service domain) IMAP/POP services both use the same, on SMTP (outgoing) set to use SMTP Auth same as imap/pop login.
There used to be some videos for this but the updates of every app change the places and wording, gets hard to keep up.
