Simple Machines Forum
Does anyone have any feedback on the Simple Machines Forum?
It looks pretty awesome, but not sure about security with it.
http://www.simplemachines.org/index.php
James :wink:
It is better than phpbb :smiley:
[QUOTE=Stephen]
I have heard about security issues with phpbb that is a concern even so they say phpbb2 is safer. The forum you guys use is also good, I might just pay for vbulletin not sure yet.
:wink:
If you want to try a free,secure, and fast forum try this:
GitHub - fudforum/FUDforum: FUDforum is a high-performance and scalable discussion forum system. It is highly customizable and supports unlimited users, forums, posts, topics, polls, and attachments. It can import XML feeds and synchronize with Usenet groups and mailing lists (including bidirectional synchronization). · GitHub
[QUOTE=Stephen]
K cool, Thanks stephen. Trying now. :wink:
SMF is a nice forum, but the developer need a life adjustment (take out to the back and beaten). On the front he plays nice but he’s quite a … jerk .. to put it nicely.
There are major theme bugs in 1.0.5 version that the developer refuse to fix. Including the newest 1.1.x version. So I wouldnt recommend it to anybody due to lack of … real developer.
vbulletin is very over priced for what it does, and the phpbb import usually never work, plus the devs refuse to fix the import, so go figure :slight_smile:
I havent found a decent forum software yet …
ummm… anybody heard of www.webwizguide.info? best asp based forum out there…
definately, webwizguide is probably the most efficient forum software written. The actual webwizguide.info website that we host uses less than 5% of the CPU and the server hardly ever needs a reboot
