2 of my domains safetymanagementinc.com and safetymi.westomahatech.com are VERY slow loading. most of the time they just time out. Sometimes I get “service unavailable”. Received calls from lots of users about the issue.
What’s the deal??
What’s the deal??
First one is loading really fast, 2nd one is slow and I am checking it.
the first one is loading, but definitely not really fast. Taking 10-30 seconds to load.
It loaded in 2 here, but i found the problem and having to reboot to fix it
posted to status.
loading right up now, just need to go ask adaptec why their raid card really suck with using a drive out of raid(only log files are there, but it makes iis have issues if the drive goes offline), The drive is perfectly fine, Adaptec does some routine check of the drive and sometimes it doesn’t bring it back online. Win20 and win22 this happens between 2:18 and 2:35am but win21 it happens in the morning. I have looked thorugh all the options and not found a timer for this, I will be calling them up to inquire.
