Site Speed Issues
I have to say I am not overly impressed so far with the speed of our sites at Jodohost. We have some test sits both static HTML from the Site Builder as well as ASP.NET and DNN sitrs and they all seem to be slow loading.
HTML - http://www.corl.ca/
ASP.NET - http://easyhr.corl.ca/
DNN - http://easyhr.corl.ca/
On each you can watch it load each graphic and the sites just don’t have that pop to them and appear sluggish.
Can you please check the servers to see if there are any issues or comment on what might be the problem.
They seem to be loading well from the UK. Don’t seem slow at all.
all under a second total load time for me, on comcast cable.
Hmm, must be from my ISP for some reason.
Thanks to those that checked. I’d appreciate other feedback on speed from anyone.
schooner,
Can you please post a tracert to see if we can identify any network related issues?
under a second loading :slight_smile:
It seems pretty respectable to me from the West Tennessee.
Pinging www.corl.ca [204.14.108.85] with 32 bytes of data:
Ping statistics for 204.14.108.85:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 96ms, Maximum = 100ms, Average = 97ms
Tracing route to www.corl.ca [204.14.108.85]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms 192.168.0.1
2 46 ms 48 ms 46 ms 68.152.202.125
3 46 ms 49 ms 46 ms 68.152.202.105
4 48 ms 49 ms 46 ms 205.152.246.25
5 66 ms 66 ms 65 ms axr00msy-7-0-0-3.bellsouth.net [65.83.237.76]
6 70 ms 131 ms 77 ms pxr00msy-0-0-0.bellsouth.net [65.83.236.32]
7 67 ms 67 ms 67 ms 500.so-1-0-0.GW5.NOL1.ALTER.NET [65.208.10.245]
8 67 ms 66 ms 67 ms 0.so-3-0-0.XL1.NOL1.ALTER.NET [152.63.102.98]
9 105 ms 106 ms 102 ms 0.so-7-0-0.XL1.MIA4.ALTER.NET [152.63.86.189]
10 95 ms 92 ms 95 ms POS6-0.GW4.MIA4.ALTER.NET [152.63.82.141]
11 98 ms 96 ms 96 ms internap-gw.customer.alter.net [157.130.85.222]
12 96 ms 97 ms 97 ms border5.pc1.bbnet1.mia003.pnap.net [69.25.0.13]
13 98 ms 96 ms 97 ms webhosting-9.border5.mia003.pnap.net [216.52.162.66]
14 95 ms 95 ms 97 ms 204.14.108.85
Trace complete.
Reply from 204.14.108.85: bytes=32 time=82ms TTL=113
Reply from 204.14.108.85: bytes=32 time=80ms TTL=113
Reply from 204.14.108.85: bytes=32 time=81ms TTL=113
Reply from 204.14.108.85: bytes=32 time=91ms TTL=113
Reply from 204.14.108.85: bytes=32 time=84ms TTL=113
Reply from 204.14.108.85: bytes=32 time=101ms TTL=113
Packets: Sent = 19, Received = 19, Lost = 0 (0% loss),
Minimum = 80ms, Maximum = 101ms, Average = 82ms
1 1 ms <1 ms <1 ms 192.168.0.1
2 * * * Request timed out.
3 11 ms 13 ms 11 ms hlfx-asr1.eastlink.ca [24.215.101.181]
4 11 ms 9 ms 12 ms hlfx-br1.eastlink.ca [24.222.79.205]
5 12 ms 13 ms 14 ms hlfxnsaldr02.bb.telus.com [154.11.184.37]
6 46 ms 44 ms 44 ms HLFXNSALBR01.bb.telus.com [154.11.7.194]
7 45 ms 44 ms 44 ms mtrlpqfbbr00.bb.telus.com [204.225.243.197]
8 46 ms 48 ms 44 ms toroonnlbr00.bb.telus.com [204.225.243.169]
9 * * * Request timed out.
10 46 ms 44 ms 48 ms CHCNIL23GR01.bb.telus.com [154.11.11.118]
11 46 ms 44 ms 44 ms dcr1-so-3-2-0.Chicago.savvis.net [208.175.10.89]
12 64 ms 78 ms 63 ms bcs1-so-3-0-0.Washington.savvis.net [204.70.192.
25]
13 76 ms 63 ms 77 ms dcr1-so-3-0-0.Atlanta.savvis.net [204.70.192.53]
14 74 ms 76 ms 89 ms acr1-so-7-0-0.Miami.savvis.net [204.70.193.189]
15 90 ms 86 ms 89 ms bpr2-so-0-0-0.Miamimit.savvis.net [208.172.99.82
16 88 ms 81 ms 88 ms bpr2-so-7-0-0.Miamimit.savvis.net [208.172.99.86
17 80 ms 84 ms 81 ms border5.pc1.bbnet1.mia003.pnap.net [69.25.0.13]
18 81 ms 82 ms 84 ms webhosting-9.border5.mia003.pnap.net [216.52.162
.66]
19 84 ms 79 ms 79 ms 204.14.108.85
Trace complete.
The ping and trace look find, I just find the sites sluggish loading, especially the graphic elements.
Not sluggish at all here, loads up very quickly. Could it be something in the way your browser treats images? Try using a different browser
Here’s the log from my browser for requesting http://www.corl.ca/
00:00:00.000 1.062 14002 GET 200 text/html http://www.corl.ca/
00:00:01.095 0.153 335 GET 200 image/gif http://www.corl.ca/widgets/spacer.gif
00:00:01.096 0.315 1205 GET 200 image/gif http://www.corl.ca/widgets/gen_124.1.gif
00:00:01.097 0.307 1947 GET 200 image/gif http://www.corl.ca/widgets/gen_103.1.gif
00:00:01.113 0.476 2750 GET 200 image/gif http://www.corl.ca/widgets/gen_104.1.gif
00:00:01.114 0.473 1341 GET 200 image/gif http://www.corl.ca/widgets/gen_125.1.gif
00:00:01.115 0.607 409 GET 200 image/gif http://www.corl.ca/widgets/gen_126.1.gif
00:00:01.115 0.658 2293 GET 200 image/gif http://www.corl.ca/widgets/gen_105.1.gif
00:00:01.139 0.734 330 GET 200 image/gif http://www.corl.ca/widgets/gen_123.1.gif
00:00:01.140 0.765 335 GET 200 image/gif http://www.corl.ca/widgets/gen_127.1.gif
00:00:01.141 1.055 366 GET 200 image/gif http://www.corl.ca/widgets/gen_122.1.gif
00:00:01.117 0.930 1174 GET 200 image/gif http://www.corl.ca/widgets/gen_129.1.gif
00:00:01.142 0.889 1383 GET 200 image/gif http://www.corl.ca/widgets/gen_132.1.gif
00:00:01.142 1.348 1374 GET 200 image/gif http://www.corl.ca/widgets/gen_134.1.gif
00:00:01.143 1.067 1230 GET 200 image/gif http://www.corl.ca/widgets/gen_136.1.gif
00:00:01.145 1.183 320 GET 200 image/gif http://www.corl.ca/widgets/gen_113.1.gif
00:00:01.146 1.225 1172 GET 200 image/gif http://www.corl.ca/widgets/gen_128.1.gif
00:00:01.147 1.564 23637 GET 200 image/gif http://www.corl.ca/widgets/gen_106.1.gif
00:00:01.150 1.484 318 GET 200 image/gif http://www.corl.ca/widgets/gen_112.1.gif
00:00:01.152 1.616 330 GET 200 image/gif http://www.corl.ca/widgets/gen_110.1.gif
00:00:01.153 2.170 41800 GET 200 image/gif http://www.corl.ca/widgets/gen_108.1.gif
00:00:01.150 2.120 28483 GET 200 image/gif http://www.corl.ca/widgets/gen_107.1.gif
00:00:01.155 2.705 1146 GET 200 image/gif http://www.corl.ca/widgets/gen_130.1.gif
00:00:01.156 2.288 7891 GET 200 image/gif http://www.corl.ca/widgets/gen_115.1.gif
00:00:01.158 2.613 1147 GET 200 image/gif http://www.corl.ca/widgets/gen_116.1.gif
00:00:01.159 2.301 328 GET 200 image/gif http://www.corl.ca/widgets/gen_109.1.gif
00:00:01.160 2.417 335 GET 200 image/gif http://www.corl.ca/widgets/gen_114.1.gif
00:00:01.161 2.468 1250 GET 200 image/gif http://www.corl.ca/widgets/gen_118.1.gif
00:00:01.162 2.557 1254 GET 200 image/gif http://www.corl.ca/widgets/gen_117.1.gif
00:00:01.162 2.759 400 GET 200 image/gif http://www.corl.ca/widgets/gen_120.1.gif
00:00:01.164 2.969 331 GET 200 image/gif http://www.corl.ca/widgets/gen_121.1.gif
00:00:01.165 2.829 319 GET 200 image/gif http://www.corl.ca/widgets/gen_131.1.gif
00:00:01.166 2.893 377 GET 200 image/gif http://www.corl.ca/widgets/gen_119.1.gif
Considering there are over 30 graphic elements on the page that is quite good.
Hope that helps.
largerabbit - How did you generate that log?
Hello,
I used Httpwatch ( http://www.httpwatch.com/ )
It is an IE plugin. Absolutely fantastic tool. Great if you are a designer, programmer etc. Very useful for finding problems/refining your sites.
Also, if you are a Firefox fan, check out the free tool at Web Developer
Amazingly useful for live CSS editing and showing you images marked in live pages etc.
Cheers.
Schooner,
Hope you don’t mind me saying, but there are a few biggish gifs on the page that would be much smaller as jpegs without much (if any) loss in visual quality. That would speed up the graphics dropping in alot.
Cheers.
Thanks.
The www.corl.ca site is built all from Site Builder in the control panel so I am not suprised on the size and such.
My results from www.corl.ca so I guess it seems ok, just seems to appear sluggish in browser at times. Odd.
00:00:00.000 0.118 14002 GET 200 text/html http://www.corl.ca/
00:00:00.120 0.137 335 GET 200 image/gif http://www.corl.ca/widgets/spacer.gif
00:00:00.120 0.134 1205 GET 200 image/gif http://www.corl.ca/widgets/gen_124.1.gif
00:00:00.121 0.284 1947 GET 200 image/gif http://www.corl.ca/widgets/gen_103.1.gif
00:00:00.122 0.224 330 GET 200 image/gif http://www.corl.ca/widgets/gen_123.1.gif
00:00:00.124 0.330 2750 GET 200 image/gif http://www.corl.ca/widgets/gen_104.1.gif
00:00:00.124 0.397 1341 GET 200 image/gif http://www.corl.ca/widgets/gen_125.1.gif
00:00:00.125 0.420 409 GET 200 image/gif http://www.corl.ca/widgets/gen_126.1.gif
00:00:00.126 0.484 335 GET 200 image/gif http://www.corl.ca/widgets/gen_127.1.gif
00:00:00.126 0.512 366 GET 200 image/gif http://www.corl.ca/widgets/gen_122.1.gif
00:00:00.126 0.594 2293 GET 200 image/gif http://www.corl.ca/widgets/gen_105.1.gif
00:00:00.127 0.619 1174 GET 200 image/gif http://www.corl.ca/widgets/gen_129.1.gif
00:00:00.128 0.706 1383 GET 200 image/gif http://www.corl.ca/widgets/gen_132.1.gif
00:00:00.128 0.712 1374 GET 200 image/gif http://www.corl.ca/widgets/gen_134.1.gif
00:00:00.129 0.800 320 GET 200 image/gif http://www.corl.ca/widgets/gen_113.1.gif
00:00:00.129 0.826 1230 GET 200 image/gif http://www.corl.ca/widgets/gen_136.1.gif
00:00:00.131 0.894 1172 GET 200 image/gif http://www.corl.ca/widgets/gen_128.1.gif
00:00:00.131 0.956 23637 GET 200 image/gif http://www.corl.ca/widgets/gen_106.1.gif
00:00:00.133 0.982 318 GET 200 image/gif http://www.corl.ca/widgets/gen_112.1.gif
00:00:00.133 1.109 330 GET 200 image/gif http://www.corl.ca/widgets/gen_110.1.gif
00:00:00.134 1.260 41800 GET 200 image/gif http://www.corl.ca/widgets/gen_108.1.gif
00:00:00.131 1.251 28483 GET 200 image/gif http://www.corl.ca/widgets/gen_107.1.gif
00:00:00.135 1.494 1146 GET 200 image/gif http://www.corl.ca/widgets/gen_130.1.gif
00:00:00.135 1.505 1147 GET 200 image/gif http://www.corl.ca/widgets/gen_116.1.gif
00:00:00.136 1.594 1250 GET 200 image/gif http://www.corl.ca/widgets/gen_118.1.gif
00:00:00.137 1.606 7891 GET 200 image/gif http://www.corl.ca/widgets/gen_115.1.gif
00:00:00.138 1.694 328 GET 200 image/gif http://www.corl.ca/widgets/gen_109.1.gif
00:00:00.139 1.712 335 GET 200 image/gif http://www.corl.ca/widgets/gen_114.1.gif
00:00:00.140 1.786 331 GET 200 image/gif http://www.corl.ca/widgets/gen_121.1.gif
00:00:00.141 1.808 319 GET 200 image/gif http://www.corl.ca/widgets/gen_131.1.gif
00:00:00.141 1.878 377 GET 200 image/gif http://www.corl.ca/widgets/gen_119.1.gif
00:00:00.142 1.904 1254 GET 200 image/gif http://www.corl.ca/widgets/gen_117.1.gif
00:00:00.143 1.967 400 GET 200 image/gif http://www.corl.ca/widgets/gen_120.1.gif
Test from sedmha.corl.ca
Thnaks to all that have help on this.
00:00:00.000 0.714 31032 GET 200 text/html; charset=utf-8 http://sedmha.corl.ca/
00:00:00.443 0.194 441 GET 200 text/css http://sedmha.corl.ca/DesktopModules/Survey/module.css
00:00:00.445 0.492 15759 GET 200 text/css http://sedmha.corl.ca/Portals/_default/default.css
00:00:00.447 0.387 3988 GET 200 text/css http://sedmha.corl.ca/Portals/_default/Skins/sedmha/skin.css
00:00:00.448 0.497 3117 GET 200 text/css http://sedmha.corl.ca/Portals/0/portal.css
00:00:00.449 0.641 11460 GET 200 application/x-javascript http://sedmha.corl.ca/js/dnncore.js
00:00:01.122 0.109 6485 GET 200 application/x-javascript http://sedmha.corl.ca/DesktopModules/TMinus/TMinus.js
00:00:01.255 0.344 74583 GET 200 application/x-javascript http://sedmha.corl.ca/controls/SolpartMenu/spmenu.js
00:00:01.704 0.098 3988 GET 200 text/css http://sedmha.corl.ca/portals/_default/skins/sedmha/skin.css
00:00:01.823 0.111 5093 GET 200 image/jpeg http://sedmha.corl.ca/portals/_default/skins/sedmha/graphic/sedmha_mainbg.jpg
00:00:01.823 0.124 3330 GET 200 image/jpeg http://sedmha.corl.ca/portals/_default/skins/sedmha/graphic/sedmha_r1_1.jpg
00:00:01.824 0.229 1535 GET 200 image/jpeg http://sedmha.corl.ca/portals/_default/skins/sedmha/graphic/sedmha_r1_but_home.jpg
00:00:01.825 0.232 678 GET 200 image/jpeg http://sedmha.corl.ca/portals/_default/skins/sedmha/graphic/sedmha_r1_background.jpg
00:00:01.824 0.331 1882 GET 200 image/jpeg http://sedmha.corl.ca/portals/_default/skins/sedmha/graphic/sedmha_r1_but_noflash.jpg
00:00:01.827 0.334 1879 GET 200 image/jpeg http://sedmha.corl.ca/portals/_default/skins/sedmha/graphic/sedmha_r1_2.jpg
00:00:01.827 0.436 6171 GET 200 image/jpeg http://sedmha.corl.ca/portals/_default/skins/sedmha/graphic/sedmha_r2_1.jpg
00:00:01.828 0.442 470 GET 200 image/jpeg http://sedmha.corl.ca/portals/_default/skins/sedmha/graphic/sedmha_r2_menu_background.jpg
00:00:01.828 0.542 522 GET 200 image/jpeg http://sedmha.corl.ca/portals/_default/skins/sedmha/graphic/sedmha_r2_2.jpg
00:00:01.830 0.547 782 GET 200 image/jpeg http://sedmha.corl.ca/portals/_default/skins/sedmha/graphic/sedmha_r2_3.jpg
00:00:01.830 0.640 2492 GET 200 image/jpeg http://sedmha.corl.ca/portals/_default/skins/sedmha/graphic/sedmha_r4_whitespace.jpg
00:00:01.831 0.667 22219 GET 200 image/jpeg http://sedmha.corl.ca/portals/_default/skins/sedmha/graphic/sedmha_r4_flashbg.jpg
00:00:01.847 0.731 338 GET 200 image/gif http://sedmha.corl.ca/images/breadcrumb.gif
00:00:01.847 0.796 335 GET 200 image/gif http://sedmha.corl.ca/images/menu_down.gif
00:00:01.831 0.851 2013 GET 200 image/jpeg http://sedmha.corl.ca/portals/_default/skins/sedmha/graphic/sedmha_r3_1.jpg
00:00:01.852 0.883 955 GET 200 image/jpeg http://sedmha.corl.ca/portals/_default/skins/sedmha/graphic/sedmha_r3_3.jpg
00:00:01.853 0.927 1036 GET 200 image/jpeg http://sedmha.corl.ca/portals/_default/skins/sedmha/graphic/sedmha_sidebar_top.jpg
00:00:01.854 0.979 1950 GET 200 image/jpeg http://sedmha.corl.ca/portals/_default/skins/sedmha/graphic/sedmha_r3_title_filler.jpg
00:00:01.855 1.023 1863 GET 200 image/jpeg http://sedmha.corl.ca/portals/_default/skins/sedmha/graphic/sedmha_r3_2.jpg
00:00:01.855 1.071 607 GET 200 image/jpeg http://sedmha.corl.ca/portals/_default/skins/sedmha/graphic/sedmha_r3_submenu_bg.jpg
00:00:01.853 1.117 332 GET 200 image/gif http://sedmha.corl.ca/Portals/_default/Containers/sedmha/spacer.gif
00:00:01.857 1.164 319 GET 200 image/gif http://sedmha.corl.ca/DesktopModules/Survey/red.gif
00:00:01.857 1.244 2604 GET 200 image/jpeg http://sedmha.corl.ca/Portals/0/xx_fillerlogos.jpg
00:00:01.856 1.338 659 GET 200 image/jpeg http://sedmha.corl.ca/portals/_default/skins/sedmha/graphic/sedmha_sidebar_background.jpg
00:00:01.861 1.297 38258 GET 200 image/gif http://sedmha.corl.ca/Portals/0/sedmha1.gif
00:00:01.862 1.479 4996 GET 200 image/jpeg http://sedmha.corl.ca/Portals/0/sedmha_info_spacer.jpg
00:00:01.863 1.483 723 GET 200 image/jpeg http://sedmha.corl.ca/portals/_default/skins/sedmha/graphic/sedmha_rightside_top.jpg
00:00:01.863 1.612 1444 GET 200 image/jpeg http://sedmha.corl.ca/portals/_default/skins/sedmha/graphic/sedmha_sidebar_bottom.jpg
00:00:01.864 1.691 609 GET 200 image/jpeg http://sedmha.corl.ca/portals/_default/skins/sedmha/graphic/sedmha_rightside_background.jpg
00:00:01.865 1.598 2904 GET 200 image/jpeg http://sedmha.corl.ca/portals/_default/skins/sedmha/graphic/sedmha_info_bottom.jpg
00:00:01.865 1.702 744 GET 200 image/jpeg http://sedmha.corl.ca/portals/_default/skins/sedmha/graphic/sedmha_rightside_bottom.jpg
00:00:01.866 1.783 867 GET 200 image/jpeg http://sedmha.corl.ca/portals/_default/skins/sedmha/graphic/sedmha_r5_footer1.jpg
00:00:01.866 1.806 1377 GET 200 image/jpeg http://sedmha.corl.ca/Portals/0/sponsors/sedmha_sponsor_bk1.jpg
00:00:01.868 1.949 1697 GET 200 image/jpeg http://sedmha.corl.ca/Portals/0/sponsors/sedmha_sponsor_farmers1.jpg
00:00:01.868 1.943 1343 GET 200 image/jpeg http://sedmha.corl.ca/Portals/0/sponsors/sedmha_sponsor_gatorade1.jpg
00:00:01.869 2.049 1850 GET 200 image/jpeg http://sedmha.corl.ca/Portals/0/sponsors/sedmha_sponsor_pepsi1.jpg
00:00:01.869 2.057 1881 GET 200 image/jpeg http://sedmha.corl.ca/Portals/0/sponsors/sedmha_sponsor_aliant1.jpg
00:00:01.869 2.153 1055 GET 200 image/jpeg http://sedmha.corl.ca/portals/_default/skins/sedmha/graphic/sedmha_r5_footer2.jpg
00:00:01.867 2.168 642 GET 200 image/jpeg http://sedmha.corl.ca/portals/_default/skins/sedmha/graphic/sedmha_r5_footerbg.jpg
