Sailor
April 4, 2008, 1:32am
1
One of my clients wants to run a piece of commercial software called SlideShowPro Director. http://slideshowpro.net/products/slideshowpro_director/slideshowpro_director
They have a compatibility test which I downloaded and it checked out. (I think all it needs that’s special is GD libraries). It uses PHP and mySQL.
Just wondering if you have any experience with this, any server issues?
We have one client that has used it before without problems I believe on shared and then on VPS as well.
pakoda
April 4, 2008, 2:53am
3
I’ve used it on shared hosting and it works well. You might get an error during compatibility test about an imaging library (I forgot the exact error). Just send a ticket and the support team will make the necessary changes.
Sailor
April 6, 2008, 5:24pm
4
Compatibility test reported everything ok. I just wanted to make sure it doesn’t cause any problems or use too many resources. Thanks.
