slow asp form
I have an ASP form that worked perfectly at my old host. Now there is a huge delay after hitting ?submit?. When it finally goes through, the results are emailed and submitted into an access database. http://www.woodstocksiv.com/survey/login.asp?surveyid=delivery
Do you know why it would be so slow?
I have attached some asp pages.
Kerri
action.txt (18.2 KB)
config.txt (101 Bytes)
db.lib.txt (2.65 KB)
I just tried it and it works pretty fast.
Richard M.
