SMTP+PHP Problem...
I have a problem with my PostNuke, when a user trying to register the system registering him and telling him that he will get a conf email but the emails are not sending.
there is no error after the registeration.
I think that its connected to the new SMTP rules.
How can I fix it?
I am also having the same e-mail problem with DotNetNuke (ASP.NET) and smtp e-mail. The mailing feature used to work, but has stopped quite recently. Any thoughts would be appreciated.
Jon
Hi
What sort of email configuration have you specified?
I will double-check it when Win6 comes back up, but I have tried it with SMTP auth enabled and without. Once I get back on my site I’ll get you the error message.
Jon
I checked the config once again and noticed I was using an alias to try and authenticate. I changed it to the primary account name and it seems to be working now.
Jon
