Hi, I just grab the following code from previous thread in the forum, everything has been set correctly, i reckon. The page return with “Success”, but i haven’t received any mail in my inbox. Was that Normal, or i should replace “localhost” by the ISP’s mail.domain.com so that i could get a mail, or it’s also working by other localhost configuration? Thanks
<?php ini_set("SMTP","localhost"); ini_set("sendmail_from","[email protected]"); if (mail("[email protected]","This is a test","This is the body","From: [email][email protected][/email]\r\nContent-type: text/plain\r\n\r\n")) { print "Success"; } else { print "Failed"; } ?>Martin, I always use the SMTP server address in scripts like yours rather than just Localhost.
[QUOTE=BluJag]
sorry abt the rookie questions…what’s the smtp server address for my local computer?
smtp.myusername.com or sth like that?
Your local computer!? Surely you are running this on a server, in which case it will something like mail.mydomain.com
[QUOTE=BluJag]
BluJag, So if my computer name is martin, which will be mail.martin.com ? i’m installing apache, how do i know mydomin name? Thanks a lot
Sorry Martin - you are way out of your depth here. Suggest you do a lot of reading and or attend 3 yr college course.
i attempted to set up a local SMTP server once… what a headache…
