Is anyone else having problems sending mail from Outlook to their JH account? I keep getting timeout errors when trying to connect to the JH SMTP server. I can successfully send mail to my other ISP’s SMTP servers so I don’t believe it’s a PC issue.
[QUOTE=tanmaya]
What is the output of “telnet mail.yourdomain.tld 25”?
I get a timeout error. I checked the SMTP servers that do work, and one is my ISP’s (this should always work and it does) and the other is gmail. However, gmail uses SSL so it’s not the standard port. So it does appear as is my ISP has blocked port 25.
I cant get email from the smtp server either (using MS Outlook). Port 25 doesn’t work. Port 587 doesn’t work. They claim to have fixed the problem, they closed my tickets but I still can’t send my email via my JodHost account. My other accounts are working fine.
[QUOTE=Stephen]
Port 587 is the alternative SMTP port, it works as most ISPs don’t block it.
Thanks Stephen. I might try that later. I was able to get everything working again by using my ISP’s SMTP server. I’m not happy with this change imposed on me by my ISP, but it’s not like I have a choice.
