Some questions
Hey all,
I have a customer with some questions. Can someone help me answer them?
Some questions:
  1. What is your ColdFusionMX version?
  2. Do you allow CF tags like CFFILE? I think I remember yes
  3. Does the wwwroot files share the disk space with the database? Yes
  4. Do you allow connection to your MS SQL through Enterprise Manager? Yes
[QUOTE=shamrox]
Depends on how your package is configured. If you use Summary Diskspace to limit disk usage, yes. It’s possible to define maximum sizes for SQL, Web and Mail though.
I think i know that but do you know what version of coldfusion is being used?
