When I’m using the control panel and select a funtion that opens up another window (Support Center for example) it takes me back to the login screen.
What’s going on?
What’s going on?
i have just checked and it worked fine.
what browser are you using as i have had issues with firefox sometimes..
make sure that cookies/sessions and you could also add the Control panel on the white list.
I don’t know what happened but I re-booted and it’s fine. It was obviously something client side.
Thanks anyway.
