spamhaus again
again a spamhaus block:
451 http://www.spamhaus.org/query/bl?ip=82.169.83.199
this is my private ip number blacklisted by my provider, thats good
but the mail is sent by the smtp from Jodo
so the mailservers at Jodo are not correctly configured
also for incoming mail, spf records are not correctly read by Jodo
a big problen and I hope Jodo will fix this soon
Mioki
It is blocking due to your own, the quickest way around this is to use port 587 for sending authenticated mail with the user/pass or use SSL with the smtp on port 465 for authentication and relay.
As for SPF, it has nothing to do with the blocklist and as far as I know is working properly, you will need to elaborate on it if there is a further problem.
thanks for your reply Steven,
But I don’t think you are right
I use several email adresses and servers
only when I use the Jodo server mail is blocked
and for the SPF:
I know that the spf has nothing to do with the blocklist
but when I recieve mail on a Jodo server, he header says
spf softfail myprivate-IP is not designate to sent mail for this domain
Mioki
