SQL book recommendation?
I’ve found myself lately turning down a couple of jobs because they involve some level of MSSQL knowledge that I don’t have.
I do okay with Access/ASP programming for my own projects, so that’s not really what I’m concerned with. These projects involve installing some pre-written application and maintaining an MSSQL database. I’ve done this with Forums etc where a built-in command allows you to back up data etc. but I may need to know more than where the ‘backup’ link is. So I’d need to know how it all works in a shared-server environment, how to use cheap/free software to make backups/restores, and probably how to occasionally make minor modifications to code and databases. I do need to know the differences between coding for Access and coding for SQL, but I’m guessing that’s really a different subject, and a different book.
So I don’t think I need a book that explains how to make SQL queries etc. Neither do I need a book that tells me how to set up IIS to run MSSQL, as I won’t be doing that. I need a book (or two) that specifically tells me how to manage SQL databases in a shared server environment, what all the terms mean, and what I should look out for when a client asks about a piece of software they may want me to install and manage.
Any suggestions?
Best bet is MSSQL Books online that comes with MSSQL. Download the free desktop version either 2005 express or MSDE and play.
http://www.microsoft.com/technet/prodtechnol/sql/default.mspx
http://doc.ddart.net/mssql/sql2000/html/
Guess I’ll have to bite the bullet and do that.. thanks
Bite what bullet? It’s free. And the best out there.
‘Bite the bullet’ meaning it’s not something I really want to spend time on but at some point I’m going to have to. I wasn’t referring to your particular suggestion directly (and your suggestion is better than all the other ones I got…)
The cost of a book or two isn’t really much compared to the time I’ll have to put into it, so free’s good, but it’s not everything.
