Where do you change the settings to allow remote connections to databases for scripts and/or programs such as SQLyog?
MySQL or MSSQL?
MySQL should be enabled, but may need a firewall rule, MSSQL is required to be set in the SQL Configuration settings and SQL restarted afterwards
