sql dbs and domain
yo.. im planning on moving to jodohost.. it sounds great, but first i have some questions:
1. In the cheapest windows plan i get 1x mssql db, 1x mysql db and 1x postgresql(or whateva) is it possible to get 3 ms sql databases instead of one of each?
2. do i get 3 domains(domain.com, domain.net and domain2.com)?
3. if yes on q2: do i get 10 different subdomains on each domain? or will it be the same subs on all domains?
  1. Unfortunately no. You only get 1 MS SQL database
  2. yes, you can host 3 complete independent sites
  3. No, the 10 sub domains have to be shared across your 3 domains
Let me know if you have any more questions :slight_smile:
im sure i have, but cant think of any @ the moment..
To avoid any confusion regarding question 2. You don’t get the domain names, but you can host up till three domains.
[QUOTE=eko]
what does that mean? do i have to pay extra if i want my own domains?
[QUOTE=DirtBag]
Yes, the actual domains are not included. You can host upto 3 domains however.
Domain registration with us is for $8.50/year
when i go to The MSSQL Login Creation Form in H-Sphere and type something in the first field and password in the other fields and press Submit i get this message:
Internal Error, Tech Support Was Notified
What does that mean?
i use a trial account..
Yes, I’m having this problem too. JodoHost says that HSphere isn’t communicating with the MS SQL server properly and they are looking into it
PostgreSQL wont work either..
i get this error:
Failed to add user, maybe this user already exists
but i havnt added any users..
hope they fix this problem so i can try the ms sql server before my trial time is out..
This is related. We are working on this. I can assure you it will be solved within the next 24 hours
ok.. good.. thanks..
The MS SQL problem has been fixed. For PgSQL, please recreate your database and users
