<cfquery datasource="#dsn#" name="getEvents">
SELECT t1.EventId
, t1.EventName
, t1.VenueId
, t1.eventActive
, t1.EventDate
, t1.PromoterId
, t1.eventArtists
FROM tblEvents AS t1
INNER
JOIN tblEvents AS t2
ON (t1.VenueId = t2.VenueId) AND (t1.EventDate = t2.EventDate)
WHERE (((t1.EventDate) Between #variable.ODBCstartQueryDate# And #variable.ODBCendQueryDate#)
AND ((t1.eventActive)<>False))
#addEventArtistCrit#
GROUP
BY t1.EventId
, t1.EventName
, t1.VenueId
, t1.eventActive
, t1.EventDate
, t1.PromoterId
, t1.eventArtists
HAVING (((t1.EventId)=Max([t2].[eventID])));
</cfquery>
The artistID that is passed in is numeric but the values stored are comma separated values.
If I remove the wildcards and the quotes, it will find an exact match, eg. Like 11, but if I have the quotes and the wildcards I get an error, eg. Like "*11*"
Here is the error:
Data type mismatch in criteria expression
The t1.eventArtists is stored as a string so I can’t figure why I’m getting an error.
[QUOTE=hatton]
That would be my thought as well. I know with SQL Server the % is the wildcard character, not *. I think this is the same in Access.
Access does not support % as a wildcard character. It does, in fact, support the * character, as well as a few others. From MS Access help:
Matches any number of characters. It can be used as the first or last character in the character string. wh* finds what, white, and why
? Matches any single alphabetic character. B?ll finds ball, bell, and bill
Matches any single character within the brackets. B[ae]ll finds ball and bell but not bill
! Matches any character not in the brackets. b[!ae]ll finds bill and bull but not bell
Matches any one of a range of characters. You must specify the range in ascending order (A to Z, not Z to A). b[a-c]d finds bad, bbd, and bcd
Matches any single numeric character. 1#3 finds 103, 113, 123
[QUOTE=Logan]
If you’re actually in Access, you use the * but I think if you’re using Jet to access the Access DB, then you have to use %. I think.
well if its just really tripping cause of the quote around the wild card, which you have as a single quote ('), why don’t you try doing that as an entity reference? Like "e;
I’m not thinking about this one too much cause you probably got a fix by now…and I dont really feel like thinking right now.
