SQL Server date problem
Hello
Let’s assume the date is 8 Dec 2006.
I have SQL Server 2000 installed on Windows Server 2003.
The regional settings are set to English (US) which has date format of 12/08/2006.
Problem is when records are inserted in SQL Server they are entered as 08/12/2006.
I changed regional settings to English (UK) which has date format of 08/12/2006.
Now when I enter records in SQL Server they are entered as 12/08/2006.
Why is that? When I choose regional settings as US it save as UK date and when I choose regional settings UK it saves as US date!! :frowning:
By the way I am using ASP.Net 2.0 to enter records and the function I am using is Now()
you should change the default language for the sql login. surely it is in spanish.
Martin
There is only one proper way to insert dates into SQL Server. Use a region-independent format. You should only worry about the region when displaying dates, not storing them.
  • For storing dates, the ISO standard is “yyyymmdd”.
  • For date and time, it’s “yyyymmdd hh:mm:ss” (24-hour time).
  • Use single quotes around the date string.
  • If possible, always store dates in UTC time (universal time, i.e. Grenwich mean time).
For example, to insert 8 Dec 2006:
INSERT INTO tablename (datefield) VALUES (‘20061208’)
To insert 8 Dec 2006, 5:30pm:
INSERT INTO tablename (datefield) VALUES (‘20061208 17:30:00’)
Hope that helps.
Actualy,
When inserting anything in sql, you should use parameters, for security reasons. Also, this way you will not have problems with dates or other data types.
True, that is ideal. Either way is ok depending on sql skills at the time.
