If I were to sign up…
Do I have full access to Data Transformation Services on SQL Server?
If so, are these DTS packages protected within my user account or may other member of the same server, although not the same database, view these packages?
May I use CDOSYS services, called from SQL Server to email HTML newsletters to a mailing list? i.e. not via PHP nor ASP, via SQL Server stored procedures?
Yes.
DTS packages would be restricted to you.
Some people are doing this.
