Hi All
I’m about to install Oscommerce and (terror) the HSBC Payment module on a customers site. I need to install an SLL. So I go to my control panel and find;
SSL support disabled
what does this mean? 8o
One step buy and install SLL certificate
This new to me, Where is this from, Is it a full certificate and how much is it?
Import SSL certificate
Is this also for installing new certificates ? ?(
Generate self signed SSL certificate
Quick explanation about this?
I’ve read the documentation and just would like some guidence, the main thing being if I’m buying a new cert which option do I follow?
Thanks in advance
David
BTW: Great to see the easyapps installed
Ok a few things, the one step SSL, that is Commodo, and it is BRAND new, not even sure it is working to be honest
(we need to check for sure)
- SSL support disabled
It means itis off now, you should be able to enable it, and generate a CSR, to buy a certificate from anywhere.
- One step buy and install SLL certificate
Described above.
- Import SSL certificate
This is if you have the CSR already made, and want to install a third party SSL cert.
- Generate self signed SSL certificate
This is great for testing, and free. It will give a warning when visiting the site, but you can test SSL free, and not have to spend the money if the venture doesn’t go through.
Hi Stephen
Thanks, this is great info, Commodo is interesting.
I can’t see where I do this… I seem to have all ssl options ticked in the plan, any ideas what I’m doing wrong?
Cheers
David
I had to look at the new docs,
http://www.psoft.net/HSdocumentation/user/ssl.html#permanentcertificate
So, generate a TEMP cert, and copy that CSR(please keep this “on hand”, as well as the private key, they are IMPORTANT)
Once you get the CSR, you can request a cert from any company, then use the import SSL option to assign the certificate. Note, you need to be on a dedicated IP for this to work.
