SSL and Zencart
I have installed Zencart in a customer’s subdirectory and added a shared SSL per a Jodohost document.
The shared ssl is on the domain https://herdomain.m****here.biz/ (BTW, does it take a while for it to propogate?)
She is using authorize.net -
I have the cart set up, and have installed the authorize.net module and have a test account w/ them, but the it says that the it is a mismatched security certificate and recommends closing the page - then it says the page can’t be found.
Can I use the shared SSL for her - and if so, do I need to set it up differently?
Michelle
