SSL & ASPEmail
Hi!
We already have a SSL certificate from Comodo.
Can we move this certificate to a new reseller account we are thinking of setting up with your firm?
Does a reseller account support ASPEmail?
Thank you in advance.
Yes, you can move the certificate. You’ll have to email us with the intermediate authority file to install on the servers
AspEmail is installed on all servers
Hi!
Can you have a different certificate for each website that you host using the reseller package?
Does the reseller windows package support XML & XSL as well?
Of course. You can install a separate certificate on each site.
You can even use our shared cert if you want
Hi!
Does the Windows Reseller Packages support XML & XSL?
everything thats supported in windows 2003 and in the normal accounts is supported in the reseller accounts..
Hi Yash!
They sent me three certificates.
Which one is the intermetiate authority file?
