SSL installation
I wasn’t able to get a reasonable answer to this via a ticket I created so I thought I’d post it here.
I received my SSL certificate file from godaddy and according to my support guy he said I should be able:
install the SSL certificate from the text box “Install Certificate based on previously generated Certificate request”
That’s great but how do I get that information OUT of the .crt file to insert into the text box?.. or am I not seeing for forest for the trees?
Open the crt file in notepad :slight_smile:
What it contains will look much like the CSR your made to start, but with different numbers and a different header and footer.
Oh, you’ve got to be kidding! I can’t believe I was that stupid.
Thanks Stephen… for not making fun of me :wink:
