Whats the best way to do a secured section for just part of the website?
I just had the pages involved with orders in a secured directory affected by the ssl before but many site use something like secured.mysite.com . How is this correctly done?
You can create a sub domain called secured.mysite.com and buy a SSL certificate for it
So the sub domain should need a dedicated IP then right?
Yes
[QUOTE=jimsau]
Done. Thanks. 8)
