SSL Question
Is it possible for me to use my dedicated SSL certificate with your hosting.
Also, who would set it up and is there a charge?
Tbone
You can use a SSL Certifiate that you have bought elsewhere, you will need your private key and the SSL Cert Key in order to install the Certificate.
