Standard vs. Coldfusion HOsting
First off, I have been with Jodohost for a while now so I am unsure of whether I just got grandfathered into a particular package or if I have the ability to use ASP and Coldfusion as of now. The packages on the homepage seem to suggest either Standard or Coldfusion (one or the other).
I am thinking of upgrading to the Silver but now I don’t know if I keep both sets or since I use Coldfusion., I get coldfusion only support.
Make sense?
Bryan
nobody?
I guess what I am getting at is that if I go to my control panel and choose upgrade plan and choose Silver. Will I be offered a choice of Standard or Coldfusion?
Because I am on a coldfusion enabled account, will it automatically have coldfusion as my account choice?
Sorry for not getting back earlier. This will not affect your current account whether your upgrade or downgrade
The Standard/CF account separation only affects new accounts
Thanks Yash.
I am curious about something though, is DISK USAGE on a day by day basis?
Like yesterday, I guess I spiked or something because I hit my 200mb of 200mb. But my average is like 50mb. So I am confused exactly how disk usage works.
It is total of daily averages for entire month.
