Hello
I have a few sub-folders in my Outlook express. When I look at the contents of each (in particular - my wife’s Ebay folder) I only have the From and Received no Subject header which is what she needs the most - how do I get it back on there… I can find it
R
Right click on “From” or “Received” and select “Columns”. You will get a list of columns. Select “Subject” here and hit OK. Done.
ah ha! that’s where it is! Thanks!
