A hosting client of mine is having issues with running SugarCRM; part of the EasyApps Collection.
From what I can decipher, SugarCRM needs at least 10 MB to run, but the memory_limt setting in php.ini is 8 MB.
It appears that memory_limit needs a 2 MB bump, so I bumped it with a htaccess file. Not sure if this will create an issue with your configuration, but it has solved the issue; at least temporarily.
Any comments?
