Do you support the CMS’s Drupal and e107 on IIS preferably or Apache secondly. I would prefer to use IIS and have the ASP.net alternative.
Requirements for drupal: (there are multiple versions with different php requirements, latest version requires php 4.3.3, though I can go for an earlier versio of drupal with lower php requirements)
Client Challenge
e107 requirements are here.
http://wiki.e107.org/?title=HOWTO:Install_troubleshoot
We have 4.4 PHP on all servers so that is no issue.
I have personally instealled e107 on a site of mine running on windows/iis, it did not work out for my needs so I removed it but it ran very well. Drupal also works.
thanks,
I’ll sign up tomorrow then.
I’ll need multiple MySql databases. Should I assume that the package description of ‘3 MySql databases’ really means ‘3 MySql database’ processes.
AuntyBunny
No, it means 3 databases. As in you could have one username_vbulletin one username_e107 one username_drupal
